{"name":"eedomus","description":"Dale inteligencia a tu casa!","url":"https:\/\/www.eedomus.com\/es","home":"https:\/\/www.eedomus.com\/es","gmt_offset":"2","timezone_string":"","namespaces":["oembed\/1.0","wp\/v2"],"authentication":[],"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/"}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"required":false,"default":"oembed\/1.0"},"context":{"required":false,"default":"view"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/oembed\/1.0"}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true},"format":{"required":false,"default":"json"},"maxwidth":{"required":false,"default":600}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/oembed\/1.0\/embed"}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true,"description":"l\u2019URL de la ressource \u00e0 parcourir pour obtenir les donn\u00e9es oEmbed.","type":"string"},"format":{"required":false,"default":"json","enum":["json","xml"],"description":"Le format oEmbed \u00e0 utiliser.","type":"string"},"maxwidth":{"required":false,"default":600,"description":"La largeur maximale de l\u2019insert oEmbed en pixels.","type":"integer"},"maxheight":{"required":false,"description":"La hauteur maximale de l\u2019insert oEmbed en pixels.","type":"integer"},"discover":{"required":false,"default":true,"description":"D\u00e9fini s\u2019il faut ou non effectuer une requ\u00eate de d\u00e9couverte oEmbed d\u2019autres fournisseurs non-inscrits sur la liste des fournisseurs autoris\u00e9s.","type":"boolean"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/oembed\/1.0\/proxy"}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"required":false,"default":"wp\/v2"},"context":{"required":false,"default":"view"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2"}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"page":{"required":false,"default":1,"description":"Page courante dans la collection.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 renvoyer dans le groupe de r\u00e9sultats.","type":"integer"},"search":{"required":false,"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string"},"after":{"required":false,"description":"Limiter la r\u00e9ponse aux articles publi\u00e9s apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601. ","type":"string"},"author":{"required":false,"default":[],"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"author_exclude":{"required":false,"default":[],"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les articles assign\u00e9s \u00e0 des auteurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"before":{"required":false,"description":"Limiter la r\u00e9ponse aux articles publi\u00e9s avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601. ","type":"string"},"exclude":{"required":false,"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer"},"order":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string"},"orderby":{"required":false,"default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"description":"Trier la collection par attribut d\u2019objet.","type":"string"},"slug":{"required":false,"description":"Limiter le jeu de r\u00e9sultats aux articles ayant au moins un identifiant particulier.","type":"array","items":{"type":"string"}},"status":{"required":false,"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux articles associ\u00e9s \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"}},"categories":{"required":false,"default":[],"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":"array","items":{"type":"integer"}},"categories_exclude":{"required":false,"default":[],"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les \u00e9l\u00e9ments sauf ceux qui ont un terme sp\u00e9cifique assign\u00e9 \u00e0 la taxonomie categories.","type":"array","items":{"type":"integer"}},"tags":{"required":false,"default":[],"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":"array","items":{"type":"integer"}},"tags_exclude":{"required":false,"default":[],"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les \u00e9l\u00e9ments sauf ceux qui ont un terme sp\u00e9cifique assign\u00e9 \u00e0 la taxonomie tags.","type":"array","items":{"type":"integer"}},"sticky":{"required":false,"description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments qui sont \u00e9pingl\u00e9s.","type":"boolean"}}},{"methods":["POST"],"args":{"date":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string"},"date_gmt":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019objet unique de son type.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string"},"password":{"required":false,"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string"},"title":{"required":false,"description":"Le titre pour l\u2019objet.","type":"object"},"content":{"required":false,"description":"Le contenu pour cet objet.","type":"object"},"author":{"required":false,"description":"L\u2019ID pour l\u2019auteur de l\u2019objet.","type":"integer"},"excerpt":{"required":false,"description":"L\u2019extrait pour l\u2019objet.","type":"object"},"featured_media":{"required":false,"description":"L\u2019ID du m\u00e9dia mis en avant pour l\u2019objet.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cet objet.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string"},"format":{"required":false,"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"description":"Le format pour l\u2019objet.","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"},"sticky":{"required":false,"description":"D\u00e9finit si l\u2019objet doit \u00eatre trait\u00e9 en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean"},"template":{"required":false,"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher l\u2019objet.","type":"string"},"categories":{"required":false,"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie category.","type":"array","items":{"type":"integer"}},"tags":{"required":false,"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie post_tag.","type":"array","items":{"type":"integer"}}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/posts"}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"password":{"required":false,"description":"Le mot de passe pour cet article, s\u2019il est prot\u00e9g\u00e9 par un mot de passe.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"date":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string"},"date_gmt":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019objet unique de son type.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string"},"password":{"required":false,"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string"},"title":{"required":false,"description":"Le titre pour l\u2019objet.","type":"object"},"content":{"required":false,"description":"Le contenu pour cet objet.","type":"object"},"author":{"required":false,"description":"L\u2019ID pour l\u2019auteur de l\u2019objet.","type":"integer"},"excerpt":{"required":false,"description":"L\u2019extrait pour l\u2019objet.","type":"object"},"featured_media":{"required":false,"description":"L\u2019ID du m\u00e9dia mis en avant pour l\u2019objet.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cet objet.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string"},"format":{"required":false,"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"description":"Le format pour l\u2019objet.","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"},"sticky":{"required":false,"description":"D\u00e9finit si l\u2019objet doit \u00eatre trait\u00e9 en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean"},"template":{"required":false,"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher l\u2019objet.","type":"string"},"categories":{"required":false,"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie category.","type":"array","items":{"type":"integer"}},"tags":{"required":false,"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie post_tag.","type":"array","items":{"type":"integer"}}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"force":{"required":false,"default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","type":"boolean"}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"required":false,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"required":false,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}},{"methods":["DELETE"],"args":{"parent":{"required":false,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"force":{"required":false,"default":false,"description":"N\u00e9cessite la valeur \"true\", car les r\u00e9visions ne supportent pas la suppression forc\u00e9e. ","type":"boolean"}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"page":{"required":false,"default":1,"description":"Page courante dans la collection.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 renvoyer dans le groupe de r\u00e9sultats.","type":"integer"},"search":{"required":false,"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string"},"after":{"required":false,"description":"Limiter la r\u00e9ponse aux articles publi\u00e9s apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601. ","type":"string"},"author":{"required":false,"default":[],"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"author_exclude":{"required":false,"default":[],"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les articles assign\u00e9s \u00e0 des auteurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"before":{"required":false,"description":"Limiter la r\u00e9ponse aux articles publi\u00e9s avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601. ","type":"string"},"exclude":{"required":false,"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"}},"menu_order":{"required":false,"description":"Limiter le jeu de r\u00e9sultats aux articles ayant une valeur menu_order sp\u00e9cifique.","type":"integer"},"offset":{"required":false,"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer"},"order":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string"},"orderby":{"required":false,"default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"description":"Trier la collection par attribut d\u2019objet.","type":"string"},"parent":{"required":false,"default":[],"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments ayant un ID parent particulier.","type":"array","items":{"type":"integer"}},"parent_exclude":{"required":false,"default":[],"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les r\u00e9sultats, except\u00e9s ceux dont le parent porte un ID sp\u00e9cifique.","type":"array","items":{"type":"integer"}},"slug":{"required":false,"description":"Limiter le jeu de r\u00e9sultats aux articles ayant au moins un identifiant particulier.","type":"array","items":{"type":"string"}},"status":{"required":false,"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux articles associ\u00e9s \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"}}}},{"methods":["POST"],"args":{"date":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string"},"date_gmt":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019objet unique de son type.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string"},"password":{"required":false,"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string"},"parent":{"required":false,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"title":{"required":false,"description":"Le titre pour l\u2019objet.","type":"object"},"content":{"required":false,"description":"Le contenu pour cet objet.","type":"object"},"author":{"required":false,"description":"L\u2019ID pour l\u2019auteur de l\u2019objet.","type":"integer"},"excerpt":{"required":false,"description":"L\u2019extrait pour l\u2019objet.","type":"object"},"featured_media":{"required":false,"description":"L\u2019ID du m\u00e9dia mis en avant pour l\u2019objet.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cet objet.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string"},"menu_order":{"required":false,"description":"L\u2019ordre de l\u2019objet en relation \u00e0 d\u2019autres objets du m\u00eame type.","type":"integer"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"},"template":{"required":false,"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher l\u2019objet.","type":"string"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/pages"}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"password":{"required":false,"description":"Le mot de passe pour cet article, s\u2019il est prot\u00e9g\u00e9 par un mot de passe.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"date":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string"},"date_gmt":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019objet unique de son type.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string"},"password":{"required":false,"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string"},"parent":{"required":false,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"title":{"required":false,"description":"Le titre pour l\u2019objet.","type":"object"},"content":{"required":false,"description":"Le contenu pour cet objet.","type":"object"},"author":{"required":false,"description":"L\u2019ID pour l\u2019auteur de l\u2019objet.","type":"integer"},"excerpt":{"required":false,"description":"L\u2019extrait pour l\u2019objet.","type":"object"},"featured_media":{"required":false,"description":"L\u2019ID du m\u00e9dia mis en avant pour l\u2019objet.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cet objet.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string"},"menu_order":{"required":false,"description":"L\u2019ordre de l\u2019objet en relation \u00e0 d\u2019autres objets du m\u00eame type.","type":"integer"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"},"template":{"required":false,"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher l\u2019objet.","type":"string"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"force":{"required":false,"default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","type":"boolean"}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"required":false,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"required":false,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}},{"methods":["DELETE"],"args":{"parent":{"required":false,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"force":{"required":false,"default":false,"description":"N\u00e9cessite la valeur \"true\", car les r\u00e9visions ne supportent pas la suppression forc\u00e9e. ","type":"boolean"}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"page":{"required":false,"default":1,"description":"Page courante dans la collection.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 renvoyer dans le groupe de r\u00e9sultats.","type":"integer"},"search":{"required":false,"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string"},"after":{"required":false,"description":"Limiter la r\u00e9ponse aux articles publi\u00e9s apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601. ","type":"string"},"author":{"required":false,"default":[],"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"author_exclude":{"required":false,"default":[],"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les articles assign\u00e9s \u00e0 des auteurs sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"before":{"required":false,"description":"Limiter la r\u00e9ponse aux articles publi\u00e9s avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601. ","type":"string"},"exclude":{"required":false,"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer"},"order":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string"},"orderby":{"required":false,"default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"description":"Trier la collection par attribut d\u2019objet.","type":"string"},"parent":{"required":false,"default":[],"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments ayant un ID parent particulier.","type":"array","items":{"type":"integer"}},"parent_exclude":{"required":false,"default":[],"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les r\u00e9sultats, except\u00e9s ceux dont le parent porte un ID sp\u00e9cifique.","type":"array","items":{"type":"integer"}},"slug":{"required":false,"description":"Limiter le jeu de r\u00e9sultats aux articles ayant au moins un identifiant particulier.","type":"array","items":{"type":"string"}},"status":{"required":false,"default":"inherit","description":"Limiter le jeu de r\u00e9sultats aux articles associ\u00e9s \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"}},"media_type":{"required":false,"enum":["image","video","text","application","audio"],"description":"Limiter le groupe de r\u00e9sultats aux m\u00e9dias attach\u00e9s d\u2019un type particulier.","type":"string"},"mime_type":{"required":false,"description":"Limiter le groupe de r\u00e9sultats \u00e0 un type MIME particulier.","type":"string"}}},{"methods":["POST"],"args":{"date":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string"},"date_gmt":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019objet unique de son type.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string"},"title":{"required":false,"description":"Le titre pour l\u2019objet.","type":"object"},"author":{"required":false,"description":"L\u2019ID pour l\u2019auteur de l\u2019objet.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cet objet.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"},"template":{"required":false,"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher l\u2019objet.","type":"string"},"alt_text":{"required":false,"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string"},"caption":{"required":false,"description":"La l\u00e9gende du fichier joint.","type":"object"},"description":{"required":false,"description":"La description du fichier joint.","type":"object"},"post":{"required":false,"description":"L\u2019ID pour l\u2019article associ\u00e9 au fichier.","type":"integer"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/media"}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"date":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string"},"date_gmt":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019objet unique de son type.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string"},"title":{"required":false,"description":"Le titre pour l\u2019objet.","type":"object"},"author":{"required":false,"description":"L\u2019ID pour l\u2019auteur de l\u2019objet.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cet objet.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"},"template":{"required":false,"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher l\u2019objet.","type":"string"},"alt_text":{"required":false,"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string"},"caption":{"required":false,"description":"La l\u00e9gende du fichier joint.","type":"object"},"description":{"required":false,"description":"La description du fichier joint.","type":"object"},"post":{"required":false,"description":"L\u2019ID pour l\u2019article associ\u00e9 au fichier.","type":"integer"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"force":{"required":false,"default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","type":"boolean"}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/types"}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour le type de publication.","type":"string"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/statuses"}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019\u00e9tat.","type":"string"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"type":{"required":false,"description":"Limiter les r\u00e9sultats aux taxonomies associ\u00e9es un type de publication sp\u00e9cifique.","type":"string"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/taxonomies"}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour la taxonomie.","type":"string"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"page":{"required":false,"default":1,"description":"Page courante dans la collection.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 renvoyer dans le groupe de r\u00e9sultats.","type":"integer"},"search":{"required":false,"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string"},"exclude":{"required":false,"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"}},"order":{"required":false,"default":"asc","enum":["asc","desc"],"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string"},"orderby":{"required":false,"default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"description":"Trier la collection par attributs de terme.","type":"string"},"hide_empty":{"required":false,"default":false,"description":"Que ce soit pour masquer des termes non affect\u00e9es \u00e0 des articles.","type":"boolean"},"parent":{"required":false,"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer"},"post":{"required":false,"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 un article sp\u00e9cifique.","type":"integer"},"slug":{"required":false,"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"}}}},{"methods":["POST"],"args":{"description":{"required":false,"description":"Description HTML du terme.","type":"string"},"name":{"required":true,"description":"Titre HTML pour le terme.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string"},"parent":{"required":false,"description":"L\u2019ID du terme parent.","type":"integer"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/categories"}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Identificateur unique pour le terme.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Identificateur unique pour le terme.","type":"integer"},"description":{"required":false,"description":"Description HTML du terme.","type":"string"},"name":{"required":false,"description":"Titre HTML pour le terme.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string"},"parent":{"required":false,"description":"L\u2019ID du terme parent.","type":"integer"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Identificateur unique pour le terme.","type":"integer"},"force":{"required":false,"default":false,"description":"N\u00e9cessite la valeur \"true\", car les termes ne supportent pas la suppression forc\u00e9e. ","type":"boolean"}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"page":{"required":false,"default":1,"description":"Page courante dans la collection.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 renvoyer dans le groupe de r\u00e9sultats.","type":"integer"},"search":{"required":false,"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string"},"exclude":{"required":false,"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer"},"order":{"required":false,"default":"asc","enum":["asc","desc"],"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string"},"orderby":{"required":false,"default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"description":"Trier la collection par attributs de terme.","type":"string"},"hide_empty":{"required":false,"default":false,"description":"Que ce soit pour masquer des termes non affect\u00e9es \u00e0 des articles.","type":"boolean"},"post":{"required":false,"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 un article sp\u00e9cifique.","type":"integer"},"slug":{"required":false,"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"}}}},{"methods":["POST"],"args":{"description":{"required":false,"description":"Description HTML du terme.","type":"string"},"name":{"required":true,"description":"Titre HTML pour le terme.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/tags"}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Identificateur unique pour le terme.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Identificateur unique pour le terme.","type":"integer"},"description":{"required":false,"description":"Description HTML du terme.","type":"string"},"name":{"required":false,"description":"Titre HTML pour le terme.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Identificateur unique pour le terme.","type":"integer"},"force":{"required":false,"default":false,"description":"N\u00e9cessite la valeur \"true\", car les termes ne supportent pas la suppression forc\u00e9e. ","type":"boolean"}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"page":{"required":false,"default":1,"description":"Page courante dans la collection.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 renvoyer dans le groupe de r\u00e9sultats.","type":"integer"},"search":{"required":false,"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string"},"exclude":{"required":false,"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer"},"order":{"required":false,"default":"asc","enum":["asc","desc"],"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string"},"orderby":{"required":false,"default":"name","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"description":"Trier la collection par attribut d\u2019objet.","type":"string"},"slug":{"required":false,"description":"Limiter le jeu de r\u00e9sultats  aux utilisateurs ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"}},"roles":{"required":false,"description":"Limiter le r\u00e9sultat aux utilisateurs correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"}},"who":{"required":false,"enum":["authors"],"description":"Limiter le jeu de r\u00e9sultats aux utilisateurs consid\u00e9r\u00e9s comme auteurs.","type":"string"}}},{"methods":["POST"],"args":{"username":{"required":true,"description":"Nom de connexion pour l\u2019utilisateur.","type":"string"},"name":{"required":false,"description":"Nom affich\u00e9 pour l\u2019utilisateur.","type":"string"},"first_name":{"required":false,"description":"Pr\u00e9nom de l\u2019utilisateur.","type":"string"},"last_name":{"required":false,"description":"Nom de l\u2019utilisateur.","type":"string"},"email":{"required":true,"description":"L\u2019adresse e-mail pour l\u2019utilisateur.","type":"string"},"url":{"required":false,"description":"URL de l\u2019utilisateur.","type":"string"},"description":{"required":false,"description":"Description de l\u2019utilisateur.","type":"string"},"locale":{"required":false,"enum":["","en_US","fr_FR","it_IT","pt_PT"],"description":"Langue de l\u2019utilisateur.","type":"string"},"nickname":{"required":false,"description":"Le surnom de l\u2019utilisateur.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019utilisateur.","type":"string"},"roles":{"required":false,"description":"R\u00f4les assign\u00e9s \u00e0 l\u2019utilisateur.","type":"array","items":{"type":"string"}},"password":{"required":true,"description":"Mot de passe pour l\u2019utilisateur (jamais inclus).","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/users"}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Identificateur unique pour l\u2019utilisateur.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Identificateur unique pour l\u2019utilisateur.","type":"integer"},"username":{"required":false,"description":"Nom de connexion pour l\u2019utilisateur.","type":"string"},"name":{"required":false,"description":"Nom affich\u00e9 pour l\u2019utilisateur.","type":"string"},"first_name":{"required":false,"description":"Pr\u00e9nom de l\u2019utilisateur.","type":"string"},"last_name":{"required":false,"description":"Nom de l\u2019utilisateur.","type":"string"},"email":{"required":false,"description":"L\u2019adresse e-mail pour l\u2019utilisateur.","type":"string"},"url":{"required":false,"description":"URL de l\u2019utilisateur.","type":"string"},"description":{"required":false,"description":"Description de l\u2019utilisateur.","type":"string"},"locale":{"required":false,"enum":["","en_US","fr_FR","it_IT","pt_PT"],"description":"Langue de l\u2019utilisateur.","type":"string"},"nickname":{"required":false,"description":"Le surnom de l\u2019utilisateur.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019utilisateur.","type":"string"},"roles":{"required":false,"description":"R\u00f4les assign\u00e9s \u00e0 l\u2019utilisateur.","type":"array","items":{"type":"string"}},"password":{"required":false,"description":"Mot de passe pour l\u2019utilisateur (jamais inclus).","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Identificateur unique pour l\u2019utilisateur.","type":"integer"},"force":{"required":false,"default":false,"description":"N\u00e9cessite la valeur \"true\", car l\u2019utilisateur ne supporte pas la suppression forc\u00e9e.","type":"boolean"},"reassign":{"required":true,"description":"R\u00e9affectez les articles et les liens de l\u2019utilisateur supprim\u00e9 \u00e0 cet ID d\u2019utilisateur.","type":"integer"}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"required":false,"description":"Nom de connexion pour l\u2019utilisateur.","type":"string"},"name":{"required":false,"description":"Nom affich\u00e9 pour l\u2019utilisateur.","type":"string"},"first_name":{"required":false,"description":"Pr\u00e9nom de l\u2019utilisateur.","type":"string"},"last_name":{"required":false,"description":"Nom de l\u2019utilisateur.","type":"string"},"email":{"required":false,"description":"L\u2019adresse e-mail pour l\u2019utilisateur.","type":"string"},"url":{"required":false,"description":"URL de l\u2019utilisateur.","type":"string"},"description":{"required":false,"description":"Description de l\u2019utilisateur.","type":"string"},"locale":{"required":false,"enum":["","en_US","fr_FR","it_IT","pt_PT"],"description":"Langue de l\u2019utilisateur.","type":"string"},"nickname":{"required":false,"description":"Le surnom de l\u2019utilisateur.","type":"string"},"slug":{"required":false,"description":"Un identificateur alphanum\u00e9rique pour l\u2019utilisateur.","type":"string"},"roles":{"required":false,"description":"R\u00f4les assign\u00e9s \u00e0 l\u2019utilisateur.","type":"array","items":{"type":"string"}},"password":{"required":false,"description":"Mot de passe pour l\u2019utilisateur (jamais inclus).","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"}}},{"methods":["DELETE"],"args":{"force":{"required":false,"default":false,"description":"N\u00e9cessite la valeur \"true\", car l\u2019utilisateur ne supporte pas la suppression forc\u00e9e.","type":"boolean"},"reassign":{"required":true,"description":"R\u00e9affectez les articles et les liens de l\u2019utilisateur supprim\u00e9 \u00e0 cet ID d\u2019utilisateur.","type":"integer"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/users\/me"}},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"page":{"required":false,"default":1,"description":"Page courante dans la collection.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 renvoyer dans le groupe de r\u00e9sultats.","type":"integer"},"search":{"required":false,"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string"},"after":{"required":false,"description":"Limiter les r\u00e9ponses aux commentaires publi\u00e9s apr\u00e8s une date donn\u00e9e et conforme ISO8601.","type":"string"},"author":{"required":false,"description":"Limiter le jeu de r\u00e9sultats aux commentaires assign\u00e9s aux ID utilisateurs sp\u00e9cifi\u00e9s. N\u00e9cessite des droits sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"author_exclude":{"required":false,"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les commentaires assign\u00e9s aux ID utilisateurs sp\u00e9cifi\u00e9s. N\u00e9cessite des droits sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"author_email":{"required":false,"description":"Limiter le jeu de r\u00e9sultats \u00e0 une adresse email d\u2019auteur sp\u00e9cifique. N\u00e9cessite les droits correspondants.","type":"string"},"before":{"required":false,"description":"Limiter les r\u00e9ponses aux commentaires publi\u00e9s avant une date donn\u00e9e et conforme ISO8601.","type":"string"},"exclude":{"required":false,"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer"},"order":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string"},"orderby":{"required":false,"default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"description":"Trier la collection par attribut d\u2019objet.","type":"string"},"parent":{"required":false,"default":[],"description":"Limiter le jeu de r\u00e9sultats aux commentaires ayant un ID parent sp\u00e9cifique.","type":"array","items":{"type":"integer"}},"parent_exclude":{"required":false,"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID parents sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"post":{"required":false,"default":[],"description":"Limite le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 des ID d\u2019articles sp\u00e9cifiques.","type":"array","items":{"type":"integer"}},"status":{"required":false,"default":"approve","description":"Limiter le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique. N\u00e9cessite les droits correspondants.","type":"string"},"type":{"required":false,"default":"comment","description":"Limite le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 un type sp\u00e9cifique. N\u00e9cessite des droits sp\u00e9cifiques.","type":"string"},"password":{"required":false,"description":"Le mot de passe pour cet article, s\u2019il est prot\u00e9g\u00e9 par un mot de passe.","type":"string"}}},{"methods":["POST"],"args":{"author":{"required":false,"description":"L\u2019ID de l\u2019objet user, si l\u2019auteur \u00e9tait un utilisateur.","type":"integer"},"author_email":{"required":false,"description":"Adresse de messagerie pour l\u2019objet auteur.","type":"string"},"author_ip":{"required":false,"description":"Adresse IP de l\u2019auteur de l\u2019objet.","type":"string"},"author_name":{"required":false,"description":"Nom d\u2019affichage pour l\u2019objet auteur.","type":"string"},"author_url":{"required":false,"description":"URL pour l\u2019objet auteur.","type":"string"},"author_user_agent":{"required":false,"description":"Agent utilisateur pour l\u2019objet author.","type":"string"},"content":{"required":false,"description":"Le contenu pour cet objet.","type":"object"},"date":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string"},"date_gmt":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string"},"parent":{"required":false,"default":0,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"post":{"required":false,"default":0,"description":"L\u2019ID de l\u2019objet article associ\u00e9.","type":"integer"},"status":{"required":false,"description":"\u00c9tat de l\u2019objet.","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/comments"}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Le contexte dans lequel la requ\u00eate est faite ; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string"},"password":{"required":false,"description":"Mot de passe de l\u2019article parent du commentaire (si l\u2019article est prot\u00e9g\u00e9 par un mot de passe).","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"author":{"required":false,"description":"L\u2019ID de l\u2019objet user, si l\u2019auteur \u00e9tait un utilisateur.","type":"integer"},"author_email":{"required":false,"description":"Adresse de messagerie pour l\u2019objet auteur.","type":"string"},"author_ip":{"required":false,"description":"Adresse IP de l\u2019auteur de l\u2019objet.","type":"string"},"author_name":{"required":false,"description":"Nom d\u2019affichage pour l\u2019objet auteur.","type":"string"},"author_url":{"required":false,"description":"URL pour l\u2019objet auteur.","type":"string"},"author_user_agent":{"required":false,"description":"Agent utilisateur pour l\u2019objet author.","type":"string"},"content":{"required":false,"description":"Le contenu pour cet objet.","type":"object"},"date":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string"},"date_gmt":{"required":false,"description":"La date \u00e0 laquelle l\u2019objet a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string"},"parent":{"required":false,"description":"L\u2019ID du parent de l\u2019objet.","type":"integer"},"post":{"required":false,"description":"L\u2019ID de l\u2019objet article associ\u00e9.","type":"integer"},"status":{"required":false,"description":"\u00c9tat de l\u2019objet.","type":"string"},"meta":{"required":false,"description":"Champs m\u00e9tas.","type":"object"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Identifiant unique de l\u2019objet.","type":"integer"},"force":{"required":false,"default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","type":"boolean"},"password":{"required":false,"description":"Mot de passe de l\u2019article parent du commentaire (si l\u2019article est prot\u00e9g\u00e9 par un mot de passe).","type":"string"}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"required":false,"description":"Titre du site.","type":"string"},"description":{"required":false,"description":"Slogan du site.","type":"string"},"url":{"required":false,"description":"URL du site.","type":"string"},"email":{"required":false,"description":"Cette adresse est utilis\u00e9e \u00e0 des fins d\u2019administration, comme les notifications d\u2019utilisateur.","type":"string"},"timezone":{"required":false,"description":"Une ville dans le m\u00eame fuseau horaire que le v\u00f4tre.","type":"string"},"date_format":{"required":false,"description":"Un format de date commun pour tous les r\u00e9glages de dates.","type":"string"},"time_format":{"required":false,"description":"Un format d\u2019heure commun pour tous les r\u00e9glages d\u2019heures.","type":"string"},"start_of_week":{"required":false,"description":"Le num\u00e9ro du jour de la semaine \u00e0 laquelle la semaine devrait commencer.","type":"integer"},"language":{"required":false,"description":"Code local de l\u2019installation WordPress.","type":"string"},"use_smilies":{"required":false,"description":"Convertir les \u00e9motic\u00f4nes, comme :-) et :-P, en images lors de l\u2019affichage.","type":"boolean"},"default_category":{"required":false,"description":"Cat\u00e9gorie d\u2019article par d\u00e9faut.","type":"integer"},"default_post_format":{"required":false,"description":"Format d\u2019article par d\u00e9faut.","type":"string"},"posts_per_page":{"required":false,"description":"Les pages de blog affichent au maximum.","type":"integer"},"default_ping_status":{"required":false,"enum":["open","closed"],"description":"Autoriser les liens de notification d\u2019autres blogs (pings et r\u00e9troliens) sur les nouveaux articles.","type":"string"},"default_comment_status":{"required":false,"enum":["open","closed"],"description":"Autoriser les lecteurs \u00e0 publier des commentaires sur les nouveaux articles.","type":"string"}}}],"_links":{"self":"https:\/\/www.eedomus.com\/es\/wp-json\/wp\/v2\/settings"}}},"_links":{"help":[{"href":"http:\/\/v2.wp-api.org\/"}]}}
